Sharp AR-5620SL appear L1
  • genzke
    • Jun 2015
    • 5
    [Error Code] Sharp AR-5620SL appear L1
    Does anyone how to resolve this error code L1? please help.
  • laitang
    • Nov 2012
    • 627
    Re: Sharp AR-5620SL appear L1
    Content: Scanner feed trouble
    Detail: Though the specified steps of motor pulses are outputted, the mirror home position sensor remains ON.
    Cause:
    - Mirror unit abnormality
    - The scanner wire is disconnected.
    - The origin detection sensor abnormality
    - Mirror motor harness abnormality
    Check and remedy:
    - Use SIM 1-1 to check the mirror reciprocating operations.
    When the mirror does not feed:
    - Check for disconnection of the scanner wire.
    - Check the harness and the connector between the mirror motor and the MCU PWB.
    - Replace the mirror unit.
    - Replace the MCU PWB.
    When the mirror does feed:
    - Use SIM 1-2 to check the mirror home position sensor.
    • genzke
      • Jun 2015
      • 5
      Thank you it was resolve. I really appreciate your help...
