Full gray back ground MX-M503N
  • Jaws
    • Oct 2007
    • 236
    I saw a post on a MX-M363 with back ground issues but I don't think it is the same problem. I am getting a full gray back ground on prints, copies also. I swapped developer units, I swapped drum units, and I swapped transfer units, still having the same issue with this machine and it did not phase the others , they are still working fine. See my picture, scratch your head, and write down your best guess. Machine worked perfect until we moved it on site. I am thinking a back solder joint.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Full gray back ground MX-M503N
    [ATTACH=CONFIG]29653[/ATTACH]
    Check, and reseat LSU connectors.
