Trying to perform duplex scan to email using a Sharp MX-M282N MFP
  • Mr Davo
    • Dec 2011
    • 35
    Hi Everyone,
    I am using a Sharp MX-M282N MFP at my work. This MFP has the ability to photocopy two sided documents through the top paper feeder. However when scanning to email (or performing an 'Image Send') there is no duplex setting (either on the touch panel interface, or through the web admin portal).
    Can this unit be configured for duplex scanning to email? If so how does one go about configuring this feature?
    Any help here will be greatly appreciated.
    Kind Regards,
    Davo
  • ZOOTECH
    Senior member of CRS
    • 3374
    Re: Trying to perform duplex scan to email using a Sharp MX-M282N MFP
    Originally posted by Mr Davo
    Hi Everyone,
    Kind Regards,
    Davo
    Look under the original size tab, that is where you can select double sided tablet or booklet.
    • Mr Davo
      • Dec 2011
      • 35
      Hi ZOOTECH,
      Thanks for your help. You were right on the money!
      Cheers
      Davo
