I have done it for a MX-M465. Isn't exactly the same, but got it done. I hit the executable as if I was setting up on network. It expands the files to a folder. Once that happens, I went to Add a Printer and installed it manually. Select have disk, go where the folders were extracted, English A and PCL6. Select the .inf and it should go.
I think with a USB connection you would need the GDI driver, but as usual, I am probably am wrong.
"You can't trust your eyes, if your mind is out of focus"--
if it is a U model gdi driver, and N models usually PCL driver. With both the driver needs to be installed before connecting usb cable between pc and printer. Normally during driver install you have to pick usb as your port , then the driver install will tell you when to connect usb cable between printer and pc.
