SHARP AR-M165 continuous Error code L4-11 display after replacing the shifter motor
  • Philcool
    • Jun 2025
    [Error Code] SHARP AR-M165 continuous Error code L4-11 display after replacing the shifter motor
    Please Techs, help me please, my SHARP copier (AR-M165) displays "L4-11" error code continuously after I had replaced the shifter motor.
    What else do I do to stop this and then be able to use my copier please.
  • harleyrider
    • Oct 2011
    • 348
    Re: SHARP AR-M165 continuous Error code L4-11 display after replacing the shifter mot
    Use sim 3-11 to check motor operation.
    • walterman
      • 196
      The bin shift motor has to be aligned properly otherwise the L4-11 will occur every time the MFP initializes. If my memory serves me correctly the white mark on the bin shift must line up in accordance to the home position mark on the motor otherwise it codes out. I always made it a habit, when replacing the motor, to mark the position with a sharpie prior to motor replacement to avoid the dreaded L4-11 code.
      • Philcool
        How do I enter Simulation mode on my SHARP AR-M165 please.
        • Philcool
          Please tell me the entry code on how to enter Simulation mode on my SHARP AR-M165 please.
          • walterman
            • 196
            Might I suggest you call your local copier repair company.. this is job is not for an untrained person to attempt.
