MXFNX9 Stapling Issue
  • tonerjunky
    • Dec 2010
    • 23
    I have a MX5111N with a MXFNX9 internal finisher that is not stapling the entire set. It originally was completely missing the bottom sheet of each set and sometimes the second sheet as well. I replaced the take belts and both sets of rollers which usually takes care of this issue. Now it is consistently missing the bottom sheet by about 1 to 2 mm. Any thoughts would be appreciated.
  • sharptech1
    • Oct 2011
    • 163
    Re: MXFNX9 Stapling Issue
    there was a manual adjustment i was shown in school that can fix that but it was too long ago and i don't remember. contact your local sharp tech rep if tech hotline doesn't know
    • drowranger
      • Jul 2015
      • 122
      giving a good clean to Knurling belts and transport rollers might fix this. also do the new fnx9 fw 02.01
      • tech2
        I use wd40 to clean the belts and rollers it helps.
        • skookumchuck
          • Feb 2012
          • 62
          Hey, Just did a repair on this. I have been able to fix it with replacing the rollers on the shaft with the two gray belts on it. It's really fun, I would recommend a good picture before taking stuff off the shaft. Stuff only comes off from one end so 90% of the stuff comes off to get one of the rollers on. There is also a bulletin that shows a crapload of other parts that could/should be replaced as well. I just used the gray belts, the rollers on the same shaft as the gray belts and the final exit rollers.
