Ive had a sharp at a location for 5 years or so and they called with a A0-20 code Will not reset through sim 24 any any of the normal ways . unfortunately i did not back up the firmware upgrade two years ago. I did not sell them this machine and the company that did is no longer around. Machine level ctl machine production /remodeling and firmware . combination error .. any suggestions., thanks
sharp 7001N code A0-20
Tags: None
Re: sharp 7001N code A0-20
i ordered another (used) mfp pwb , i tried re=seating all dimm and e-proms rom chips. and sim 14 thru 24... we will let you know by next weekComment
the error is between the firmware and the board, the board has model specific info programmed into it and the firmware has similar info and they have to match. Since you replaced the board,(used boards are not a good thing to try) I would look at ordering new firmware dimms from Sharp, you might need to replace the eeprom(which has to be programmed by Sharp) but that usually gives U2-80 or U2-90 codes. You might want to try an emergency firmware update .Comment
Ok im getting on a tangent.. so I should try the new firmware DIMMS and/or EEPROMS. I have not done or experienced an "emergency firmware update" just the typical by the book.
thanks for all this info,much appreciated, ArnieComment
