Sharp MX 2614
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    Sharp MX 2614
    Good evening everyone !
    I recently started selling this brand.
    And I ask you this help (or at least if there was a chance to do it).
    It can, on the MX 2614, increase the area of the scanner, and, when printing, reduce the white margins at the edges of the paper?
    If so, what simulations should be used?
    Thanks for the help !
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    Re: Sharp MX 2614
    According to the sales pamphlet it can do full bleed but only with oversize paper. I would not recommend adjusting the void areas & only use OEM toner to avoid fuser jams on full bleed copies.
    theres better qualified sharp techs on here than me so they may say something different.
    Incontinentia Buttocks
    • drowranger
      • Jul 2015
      • 122
      Re: Sharp MX 2614
      According to sm printable area for
      A3 Wide 297 x 420mm
      A3 293 x 413mm
      A4 206 x 290mm
      You can change the scanner area using sim 50-27 default setting is 0mm for oc & adf.
      You can change printer area using sim 50-5 items A, b, c . default lead and rear void area is 3mm. decrease value by 1 to shift lead edge by 0.1 mm. It is not recommended to reduce this values since it can jam very easily in the fuser with paper curl. This fuser is not cheap as well. we usually increase the lead edge to minimize paper jams in fuser unit. best way is to print on A3W and gulatine. make sure you are using good paper as well
      • Ingranaggio_rotto
        • Oct 2010
        • 275
        Re: Sharp MX 2614
        A3 Wide 297 x 420mm
        A3 293 x 413mm
        A4 206 x 290mm
        Thank for the help.
        • Nachoman4life
          • Oct 2007
          • 212
          Re: Sharp MX 2614
          I personally avoid messing with the void areas, 2mm lead and trail void at minimum. Decreasing the L to T void, lead to the higher chances of the page sticking in transfer and fusing, and getting under any separation assembly. If the customer is looking for an edge to edge print, print over sized (ie..fullbleed) and trim to stock size.
          Where the heck is my spring hook?
