Sharp MX 7001N "Ghosting"
  • glenbennett
    • May 2015
    • 68
    [Misc] Sharp MX 7001N "Ghosting"
    Hello
    I am servicing a Sharp MX 7001N and I replaced the fuser unit do to the fact it had crinkles on the rollers. Now when I make color prints or copies it seem to what to duplicate color images and logos right next to the original position of the image on the paper I call it "ghosting" also the color prints are not looking like the PDF it prints from... Copies come out fine this only happens on print mode.... What might i do what type of adjustment or Simm might I do to fix this problem...
    Thank You
    Glen Bennett
    Thank You,
    Glen Bennett
  • harleyrider
    • Oct 2011
    • 348
    Re: Sharp MX 7001N "Ghosting"
    Might sound like a dumb question but did you set the fuser levers down?
    • drowranger
      • Jul 2015
      • 122
      As harleyrider mentioned check the leavers.
      If the leavers are in down position then fuser temp is low for the print jobs.
      First go to sim 43-1 and check the values with the sm. item A should be 200. someone might have reduced it. if not
      try increasing the fuser temp by 3-5 degrees in sim 43-1 items A to L for plain paper. if it works add the same amount in sim 43-4 for duplex printing in items A-J for plain paper.
