Hi all,
I read some threads on this and have replaced the 3 gears of the motor drive on the shutter assembly, one of which was stripped. When the motor is out, the shutters slide smoothely. The gear marks on the ends of the shaft and the slide rail are timed properly. Intermittently it throws a cf90 error. I read something about a modification, but something else that said it didn't apply to this machine.
Please steer me in the right direction to solve this problem.
TIA,
Brian
TIA,
Brian
