Toshiba eStudio 4520C
  • Reed
    • Feb 2011
    • 261
    This machine is constantly going into warm-up and will stay there for about 15-20 minutes. I am suspecting it is possibly something with the fuser either a lamp is going out or a thermistor. Has anyone seen this problem before. Thanks in advance
  • davod.mardani
    • Feb 2015
    • 32
    Re: Toshiba eStudio 4520C
    Format HDD with 08-690
    Sent from my SM-N900 using Tapatalk
    • Reed
      • Feb 2011
      • 261
      Thanks, I will go try that.
      • didi2005
        • May 2011
        • 401
        U can also check the heater lamp, might be 1 of the lamp burn (white color)~~~
        • Luther
          • May 2006
          • 682
          there is no lamp, remove the fuser unit and in the machine where the fuser sits is a metal plate held in with 2 screws, remove the plate and you will see two thermopiles, clean them with a cloth and some alcohol..
