C3D1 for Toshiba EStudio 356se
  • noobie1
    • Jun 2015
    • 48
    [Error Code] C3D1 for Toshiba EStudio 356se
    Could someone tell me what is wrong of this error e got after i replace a new part of black processing Unit assembley for e-studio 356se? Please I need help for those expert..Thank you.
  • didi2005
    • May 2011
    • 401
    Re: C3D1 for Toshiba EStudio 356se
    U need to perform EPU replacement mode "7+START" when new PU is replaced...
    • noobie1
      • Jun 2015
      • 48
      i followed the step and then appear adjustment processing 50% afterward its popping a error display on the screen? what other step to resolve this issue? What i did is just keeping perform epu replacement mode still appearing it.
      • Sriyanjan
        • Apr 2015
        • 79
        Startup with 3+c then clear error flags😀
        Sent from my HTC Desire 820s dual sim using Tapatalk
        • Sriyanjan
          • Apr 2015
          • 79
          • noobie1
            • Jun 2015
            • 48
            Originally posted by Sriyanjan
            [ATTACH]30755[/ATTACH]
            sir i can't read the picture you post, can high the resolution of the photo? Thank you.
            • Sriyanjan
              • Apr 2015
              • 79
              1. If the process unit has been replaced with a new one before the equipment is started, turn the power OFF and then back ON in the EPU replacement mode ([7] + [START]). 2. If the process unit has not been replaced, check the following. 3. Check if the process unit is properly installed, and check if the connector pins that are connected to the equipment are disconnected or have any abnormality such as deformation. 4. Check if the harness connected to the connector J451 on the EPU board has any abnormality
              • didi2005
                • May 2011
                • 401
                Did u follow the steps on the manual?
                • noobie1
                  • Jun 2015
                  • 48
                  sorry i dont have any manual here. thank you for this softcopy of manual you give to me. I try to follow this steps. Or if may i request a possible softcopy of PM and Service manual for toshiba, in your kindness.
