Toshiba 5560, machine keeps saying "close frontdoor"
  • Hansoon
    • Sep 2007
    • 3387
    Toshiba 5560, machine keeps saying "close frontdoor" however all doors are closed. Couldn't go deep into it yet but a quick look indicated that the interlock switch of the right hand small frontdoor was actuated and clicking, the interlock switch of the left hand large frontdoor I could measure and seemed operative as well. The interlock switch of the side door from the high capacity cassette was also actuated. Any idea's where to look for? Anymore interlock switches I overlooked? Any other reasons for this indication in the display? Hans
  • tsbservice
    Field tech
    • 8020
    Hans you may look at fuser, old Toshibas use to chain 24V via fuser so bad thermostat will be the fault, also check thermistors for cracks in their connectors, it also could be transformer at the bottom of rear cover.
    Hope that helps it was a time since I touch any of these but someone can shed more light, keep us informed and good luck.
    • Baphomet
      Copier Technician
      • Aug 2008
      • 293
      I agree with tsbservice, and digging through my analog stuff I came up with this old TechNet article:
      Sorry about the formatting, I just cut and pasted this from a PDF.
      • Hansoon
        • Sep 2007
        • 3387
        Thanks for the reply guys, will go there tomorrow and let you know. Hans
        • _____e03_____
          Go for thermostat bro..
