eStudio 356 scan to email
  • iscott
    • Mar 2010
    • 344
    All we are getting when scanning to email is "Failed to connect to SMTP Server"
    We can ping a web page IP address so the machine can get out.
    Settings all look right but we are use to Ricoh and there are a lot of terms in the set up for the toshiba that ricoh does not use.
  • Osty
    • Mar 2012
    • 4
    Re: eStudio 356 scan to email
    Are you scanning to office 365,gmail,exchange, etc.?
    • arnh79
      • 468
      A couple things to check: Make sure your DNS info is correct, otherwise that will generate the SMTP error. And on the Toshiba's you need to enter the info in the SMTP Client section, not the SMTP Server area. Also, don't forget to hit save at the top of the page after you've entered everything in the pop-up box. That one has caught me a time or two.
      Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
      • didi2005
        • May 2011
        • 401
        Make sure u fill in the email address and name on the Email Tab as well~~~
        • iscott
          • Mar 2010
          • 344
          All that you mentioned is correct. 2 things I can think of are The SMTP server info is set up but SMTP Server is disabled (Maybe that is creating a conflict) The login is not correct. (We have it as the full email address and password.) Which is how its set up in ricoh, Toshiba. There is also the possibility that the firmware needs to be upgraded. Ok 2 plus 1.
          • arnh79
            • 468
            Another thought is to try a different login protocol. The drop down list has several options, most of which I've never used. I think I've had most success with AUTO and Login. But maybe your setup requires a different one?
            • iscott
              • Mar 2010
              • 344
              tried both of those.
              • ttranthanhtam
                • Aug 2015
                • 6
                you could drive yourself photocopy machines are not
                • ttranthanhtam
                  • Aug 2015
                  • 6
                  you could drive yourself photocopy machines are not... Because HDD bab disk ... Tks
                  • MUMMIM
                    • Jan 2008
                    • 125
                    you can read here https://support.google.com/a/answer/176600?hl=en
                      • 8221
                      Double check that you have entered the Gateway correctly under the Network tab, TCP/IP.
                      • mtgstop
                        • Feb 2014
                        • 5
                        I am looking for someone to fix a E-Studio 6520C in the St Louis, MO area...
