Hello sir,
I have this problem on Toshiba 656se wen I'm using the platen glass all the copies is not jamming without sorter, and wen I'm using adf with sorter the paper jam into side door cover and the machine saying is E410 I check all the front door cover the switches and all the sensor.its a stationary jam.wen I'm using the platen glass all copies are not jamming can you help me to this problem sir.
Thank you in advance
