Toshiba e-studio 80 / sc-2 controler
  • CEEMORE
    • Sep 2008
    • 19
    I have the Toshiba E-Studio 80 copy machins with a 2-SC Controler for approximately one year and everything was working fine. All of a sudden the controller started to "BEEP" contantly after start up. If I shut the controller off and leave the copy machine power switch on the beeping stops and the copy maching still works fine.
    Can anybody suggest what would cause the controller to constanley beep?
    I am considering replacing the controller and would like to find out if there are any used SC-2 Controllers available and if so what is the cost for one that will allow network printing and scaning of documents.
  • decimal
    • Aug 2006
    • 75
    I think that SC-2 controller first is a PC so if it beeps constantly you try to check AGP card & RAM dimm on it .Good luck
    • CEEMORE
      • Sep 2008
      • 19
      DECIMAL:
      I am not very falimar with the Toshiba Studio 80 machine. Is the AGP card the card in the controller where the multiple pin cable connector connects to the copy machine. It is a small card with some ICC numbers printed on it.
      I truly appreciate your help and where can I locate a replacement card?
      I assume the only way that you can check the card is to replace it?
      AGAIN THANKS FOR THE HELP AT LEAST I NOW KNOW WERE TO LOOK FOR THE PROBLEM.
      THANK YOU
      SEYMOUR LICHT
      Phoen (480) 948-1730
      E-Mail licht6@cox.net
      • CEEMORE
        • Sep 2008
        • 19
        One important piece of information is that when i press the reset button on the front panel of the controller, the beeping stops for ablout 15 seconds and then starts again.
        • CEEMORE
          • Sep 2008
          • 19
          Another additional piece of information is that i am no longer able to print from my network while the controler is beeping, and the controller starts to beep approximately 15 seconds after i push the power button on the front face of the controller.
          I assume that inquiring minds would like to know.
          Seymour
          • CEEMORE
            • Sep 2008
            • 19
            Decimal
            i am having trouble locating the agp card in the controller
            please help.
            Seymour
            • Baphomet
              Copier Technician
              • Aug 2008
              • 293
              Originally posted by CEEMORE
              Decimal
              please help.
              Seymour
              I am assuming decimal is talking about the video card since the video card and the memory are the most common causes of BIOS beep codes in a PC.
              Here is the video card:
              • CEEMORE
                • Sep 2008
                • 19
                Bophomet:
                Thanks for the help!
                I assume item # 14 on your above expolred view is the agp card.
                Now the next problwm where can i get a replacement agp card in phoenix?
                Seymour
                • Baphomet
                  Copier Technician
                  • Aug 2008
                  • 293
                  Sorry, that I dunno. I work for Toshiba so I get all my parts from Toshiba.
                  • CEEMORE
                    • Sep 2008
                    • 19
                    Originally posted by baphomet
                    sorry, that i dunno. I work for toshiba so i get all my parts from toshiba.
                    baphomet:
                    Thanks for the information.
                    By any chance could you tell me in waht city you live in, i was not able to find it in you profile. I hang my hat in scottsdale az.
                    • Baphomet
                      Copier Technician
                      • Aug 2008
                      • 293
                      Sure, I live in Converse ... a small town just on the Northeast outskirts of San Antonio, Texas.
                      • CEEMORE
                        • Sep 2008
                        • 19
                        BAPHOMET;
                        By any chance would you know how much an AGP board cost?
                        SEYMOUR
                        • decimal
                          • Aug 2006
                          • 75
                          The AGP card used in SC2 is very old (AGP 2x ).I think you can find it in used PC (with CPU pentium III or older ) only.You should check RAM (item#13).It is SDRAM PC100 ,128 or 256MB ,very old too .
                          • CEEMORE
                            • Sep 2008
                            • 19
                            BAPHOMET:
                            I truly need help. I replaced both RAM strips in the controller and it still beeps and I still get an error message that the controller is not connecting ti the copy machine.
                            I finally called for service from Toshiba and two service men came down after about 2 hours and numerous phone calls, they cane to theconclusion that the problem is in the mother board of the controller. they further told me that the cost of a repacement mother board waed $1,500.00 plus labor to instal and test.
                            I asked then could it be the AGP board and they said no, because the problem is that the controller can not communicate with the copy machine.
                            As of today i have not been able to locate either a new or used controller.
                            Since you work for toshiba do you have any suggestions, for i sure would like to be able to print feom my computer network to my Toshiba.
                            • Baphomet
                              Copier Technician
                              • Aug 2008
                              • 293
                              I found the beep codes for the z4 controller, I am thinking they will be the same. This should lead you to the problem:
