3511/4511 toner
  • 2new2no
    • Dec 2007
    • 48
    3511/4511 toner
    Can the color toner cartridges for Imagistics CM4530 be used in a Toshiba 3511/4511 if the rear tabs are broken off with out problem?
    Is there a way to use the black toner for
    Imagistics CM4530 on the Toshiba since the rear key is clocked 1/4 turn, or will it have to be emptied into a 3511 container?
  • CopyDawg
    • Dec 2008
    • 74
    Yes you can use the imagistics or oce toner in the 3511 just break off the tabs with a set of pliers. I think you can use the imagistics black in a Toshiba too. Don't know how to do that one tho.
    • ZeusGT
      • 271
      trade the caps.. the Toshiba black toner cartridge will NOT fit into the Imagistics. You must unscrew the caps of the black toner cartridge and swap them out... I do it all the time
      CompTia A+ Certified
      CompTia Net+ Certified
      CompTia Server+ Certified
      CompTia Project+ Certified
      OP Scanshare Certified
