E-Studio 281c scan-to-network failure to create file
  • A.Waegner
    • Jul 2025
    Hello everyone, I've been trying to solve this issue for days, maybe someone can point me in the right direction.
    We've recently upgraded a clients server to a new one running windows server 2012 R2. The scaned files are supposed to go into a folder called 05 Scans. The network path we're using in the settings is \\192.168.180.200\Daten\05 Scans. The copier is configured with a static ip, correct gateway and DNS.
    First we tried to have it log in with the admin account and added the domain name to be safe. Then we created a user "scan" and gave it access to the folder. We even gave full access to everyone. It always comes up with the "failed to create file" (might not be the exact wording, I translated it).
    Thanks in advance for any advice!
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: E-Studio 281c scan-to-network failure to create file
    Am I right in the fact the IP address is for the server?
    Try the full path to the scan folder
    IE...
    \\192.168.180.200\users\public\daten\05 scans
    Check and see if there is anything between the ip and the daten folder.
    Also it maybe an smb signing issue and newer firmware is needed.
    • A.Waegner
      IE...
      The Path is correct, there is nothing missing. The server is is a virtual machine, could be causing the problem?
      So I guess we'd have to contact a certified dealer to get the firmware upgraded?
      • Mr Spock
        • Aug 2006
        • 2064
        user function > admin > list reports > list > function list
        Look in upper right of the print out for firmware version. If the last 3 numbers are 356 you have the latest.
        Is the ip address that of the virtual machine or the virtual server itself?
        • A.Waegner
          I'll check the version tomorrow. It's the ip of the virtual server itself.
          • didi2005
            • May 2011
            • 401
            Recently just encountered similar scan error "Failed to create file" on e2500c when scanned from MFP to NAS server. It might be due to firewall issue which blocked the MFP.
            • qbert69
              • Mar 2013
              • 1152
              The folder you are scanning to needs to be on the ACTUAL SERVER MACHINE--a physical hard drive....not a virtual hard drive or drive image!!!....and shared to the virtual machine(s)!!!
              Any time you are asking an MFP to traverse the virtual world and find the folder, good luck!...you're asking for more problems than answers!!!
              SIMPLIFY AS MUCH AS POSSIBLE!!!
              REACH FOR THE STARS!!!
              Konica Minolta Planetariums!
              • A.Waegner
                Thanks, but the server structure has to stay and our client doesn't want to files anywhere else. We tried using a FTP instead of SMB, but that failed aswell. Probably for the reasons you mentioned. For the time being we'll use the internal storage.
                We'll get the firmware upgraded the next time a toshiba technician is there for maintenance. Maybe afterwards it will work.
