e 166 3 bar on display
  • siraphop
    • 54
    hi there
    I replaced with compatible cartridge, when received toner light.
    but the machine keep free running and show 3 bar on digit display.
    I takes 08-971 changed 1 to 3 but still the same occur.
    Please pull me out .
    thanks you
    siraphop
  • Baphomet
    Copier Technician
    • Aug 2008
    • 293
    Sounds like the wrong toner cartridge to me. Be sure that T-1640 is on the cartridge.
    If that is not the problem, then I am at a loss.
    • mckinley
      Chief Twiddler
      • Dec 2006
      • 150
      if i'm not mistaken, there should be a small square of card taped to the rear of the cartridge. this covers a circuit board. you have to remove this card. if there's no card / no circuit then the chances are you are using non genuine toner which the machine will reject.
      Happiness Is The Road.
      • tsbservice
        Field tech
        • 8082
        It's not unheard for us that this toner cartridge detection board fails, had a few in a field.
        • siraphop
          • 54
          dear tech
          I have already rid any pieces off. No change. !
          If this sign cause of the unauthorization chip . which way can recover. ?
          change new one need be the last thing to do .
          please help me .
          siraphop
          • siraphop
            • 54
            already solved
            Finally,I 've solved this problem . the paddle in cartridge broke apart
            where the toner were blocked .
            thankyou everyone for help.
