e2505AC with Bluetooth keyboard & Bluetooth antenna
    • 8197
    Is anyone having a problem getting the keyboard to connect to the copier after a copier reboot?
    Firmware is V1017y.
    The keyboard is Adesso 3.0 Bluetooth Version 2000 rubberized.
    The copier sees and discovers the Adesso no problem but it will not connect to it. The blue light LED on the keyboard is pressed and flashing.
    I did get the keyboard to connect initially but I cannot get it to connect a second time. I had an Adesso 1000 metal keyboard and the copier LCD panel and the copier kept asking me to input a password but there was no where to input a password. Even if I pressed "0000" on the keyboard, the copier would eventually say no device found. The Adesso 2000 keyboard does not ask for a password.
    I noticed that whenever the copier is forced to network initialize the user is forced to go through the process of keyboard discovery under Admin.
    • 8197
    Re: e2505AC with Bluetooth keyboard & Bluetooth antenna
    Follow the procedure. Network initialization does not require the user to reboot the keyboard. An overnight charge of the keyboard lasts approx six months.
    Works well at distances of 10 feet or more. Probably a helpful option for a person with disabilities.
