toshiba 230 photocopy problem
  • junidexy
    • Sep 2013
    • 32
    i have toshiba 230 machine when i photocopy the image copy come with white line.i change laser unit and scanner lamp.and it keep like that.
    what might cause this issue, anyone can update me what to do for this
    thanks
  • riyadh hossainbd
    • Dec 2015
    • 239
    Re: toshiba 230 photocopy problem
    thanks
    First release developer from dv unit ,then filter developer hope it will ok
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      one or more of the following:
      drum
      drum blade
      main charge unit
      developer material
      developer unit.
      With the age of this I would recommend upgrading not repairing.
      • toshibaestudio
        • Jun 2016
        • 116
        Genuine Toshiba parts, ready stocks, firmwares, manuals
        • Thomas007
          • 49
          Replace DEVELOPER
          • toshibaestudio
            • Jun 2016
            • 116
            The mixer auger inside developer tank might broken causing scratching on magnetic roller...U can see from the magnetic roller...
            If really the case, just remove the broken parts, filtered the developer material, can still run if magnetic roller not serious damage...
            • onlineprofitinternetshop
              • 17
              You might check also the upper roller in fuser..,
