replacing HDD on ES 550
  • COPYDOCAZ
    • Mar 2015
    • 110
    [Misc] replacing HDD on ES 550
    I have checked the service manual and the service handbook for replacement procedure for the HDD can anyone help?
  • MUMMIM
    • Jan 2008
    • 125
    Re: replacing HDD on ES 550
    it is very easy, you replace "hdd" right (ATA HDD) and 0+8 + POWER , 690 STAR, Wait massage : "reboot the machine" appear and do same that massage ,
    drink a cup of cool beer and relax
    MM
    • riyadh hossainbd
      • Dec 2015
      • 239
      MM
      plz discribe replacing process of ADI HDD and SATA HDD for es2040c
      • COPYDOCAZ
        • Mar 2015
        • 110
        MM
        Thanks event Ican handleit
        • ANOL
          • Jun 2016
          • 17
          i think you can read in service manual
          • COPYDOCAZ
            • Mar 2015
            • 110
            OK soooo this is a nightmare... Original service call was machine not coming to ready, called tech support and was told "bad Hard drive ". Got a new HDD I ordered from Hytec. Installed it and when I went to boot it up got a message "Reinstall the hard drive" checked and cleaned the connections. Still didn't see it. I noticed the jumper on the hard drive I got was not in the same position as the one I was installing, (don't know if this is relevant, just sayin ). I put the old one back in and tried to format it, FAILED tried update the firmware I have access to the toshiba tech site and there are at least 10 firmware packs that are for this machine with notes regarding VERSIONS. How do I know which version I have and which is the correct firmware for the unit I have. I got the newest version for the ES550 and Downloaded it took 30 min and tried to install it... By tried I mean I preformed the procedure outlined by the SM.
            The process took over 3 hours at which time the message "UPDATE FAILED" appeared. I have now spent 5 hours with no success. I will be calling Hytec on Monday for advice and a new HDD. The one they sent me is NG but how should I proceed? All this said I have 3 questions I hope some of you can help with.
            1)Can I just get the correct size and type HDD online?
            2)How do I know what firmware I need for the machine I have?
            3)How long should a firmware update take?
            and lastly, at what point do I get a block of C4 and &^%$#%&*
            Thanks in advance
