Toshiba e studio 355, dead screen and keypad not working
  • atech
    • Aug 2010
    • 89
    [Misc] Toshiba e studio 355, dead screen and keypad not working
    I checked one toshiba e studio 355. When I turned on the machine it operates but the screen is dead and the keypad is not working as well. Is the control panel defective or do I need to check the board at the back?Need some help from you guys...
  • clint@clintsimonsen.com
    • 124
    Re: Toshiba e studio 355, dead screen and keypad not working
    Check the loom and connectors
    Sent from my Nexus 5 using Tapatalk
    • atech
      • Aug 2010
      • 89
      Is it possible that HDD is at fault, because the the red and yellow led indicator are lit?
        • 124
        Try turning off and holding C+3 and turning back on see if if comes up in that mode. Or (08) mode. C3 will give you a good idea if the control panel is playing up
        • Sriyanjan
          • Apr 2015
          • 79
          I had same problem. Problem is panel pressing from something between touch panel and plastic casing.
          Sent from my HTC Desire 820s dual sim using Tapatalk
