ES 3530C Error Code C454
+ More Options
Posts
  • jferrua
    • Aug 2025
    I have a Toshiba ES 3530 that when I turn it on it gave me a "call service" message and the error code C454, then I rebotted the machine and now when it starts it allows me to change between modes (copy, print, fax) and check the counter, but the touch panel doesn`t work and after while the machine freezes. What can I do??? Any help would be appreciated....
  • gliderider
    • May 2015
    • 131
    Re: ES 3530C Error Code C454
    C454 is not a valid code for that copier. See if you can power up in Start 9 (list print mode) and key in 106 for all error codes.
    Once you have the correct error code re post it. Also what is your firmware level at?
    • jferrua
      You mean to start the copier with the 9 pressed? In any case let me try that, and then I will reply with the results. Can I get a list through the web UI?
      • gliderider
        • May 2015
        • 131
        Hold down the Start key and 9 key together while powering on. Key in 106 and press start to output the error list. 103 will print out the pm support list as 111 will give you the current firmware levels.
        • jferrua
          Will try this as soon as possible, it's been quite hectic these last few days, I will keep you posted. Thanks
