ES 257 "Toner Cartridge Not Detected"
  • wyo19
    • Nov 2012
    • 51
    I have a call (225 miles away) that does not detect the toner cartridge is installed. I ordered the 6LE58079000 ASY-HOLD-SP-TNR I'm pretty sure also known as PWA-F-CTIFToner cartridge interface PC board
    (CTIF board)
    Anybody have this problem before....
  • toshibaestudio
    • Jun 2016
    • 116
    Re: ES 257 "Toner Cartridge Not Detected"
    The toner cartridge deduction sensor 6LK27001000 might loose...try reconnect connector...
    • gideon
      • 283
      (CTIF board)
      Did this board solved the problem?
      • toshibaestudio
        • Jun 2016
        • 116
        1. Make sure the front cover can be closed properly & firmly
        2. Make sure genuine Toshiba toner is inserted
        3. If not toner problem, try clean/replce the toner CTIF sensor *Inside the machine with 6 springs that touching the toner cartridge chip
