Scan to folder... SMB scanning
  • ZeusGT
    • 271
    Does the Toshiba 350 support SMB scanning?
    Is it like the 3511 and will only let you use only two paths to scan to?
    Thanks for your time...
    CompTia A+ Certified
    CompTia Net+ Certified
    CompTia Server+ Certified
    CompTia Project+ Certified
    OP Scanshare Certified
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Yes they are the same but with the color machines it is built in and with the black and white you need to purchase the print and scan enablers (look like thumb drives).
    • ToshibaTech
      • Apr 2007
      • 580
      Also, yes... it is only able to have Remote Path 1 and 2, however if you check "allow users to select destination..." then you can use templates to set up a lot of different scanning locations. Or the user could just type in their own path when scanning (a little confusing for most.)
      I will not give you service manuals or firmware.
      • ZeusGT
        • 271
        Hey, thanks guys for all your help... Is there any Toshiba copier that will allow more than 2 SMB path addresses?
        • ToshibaTech
          • Apr 2007
          • 580
          If you make use of the templates you can create tons of different scan to locations. Just enable "allow users to select destination..." in top access and then when you register each template you can type in a location for each. The difference is the procedure when scanning will have the user pressing the templates button instead of the scan button.
          • ZeusGT
            • 271
            O.k... that does make sense. I'll give that a try. Thanks
