toshiba admin reset
If you are talking about the administrative code for the copier itself, you can print out the 08 codes by holding down START and 9 while powering on then entering 102 and press start. The Master code will be the last thing printed out on the list and you can use it to change it to something else.
If you are talking about the controller administrative password, I believe you can only set it during the controller set-up; which would mean if you lost it you would have to reinstall the controller software to set it again. If you know the old password, then I believe you can reset it from TopAccess.Leave a comment:
toshiba admin reset
Hi how i can rest the admin password on ES35
