Fax printing from a default tray
  • Phil Walling
    • Dec 2015
    • 39
    Afternoon folks,
    Hopefully a quick one and i'm not going totally bonkers.
    Anyone know how on earth I can set a specific tray that faxes print from? Have been trough 08 codes and can't see anything.
    Cheers everyone....
    Re: Fax printing from a default tray
    Originally posted by Phil Walling
    Afternoon folks,
    Cheers everyone....
    what machine?
    • Phil Walling
      • Dec 2015
      • 39
      Oh yeah, that might help. Sorry been a long day.
      Its a Toshiba 2505ac.
      • gliderider
        • May 2015
        • 131
        Generally speaking with most current Toshiba's. Select User Function/Drawer/Paper Type/ select the drawer you want and then press the Fax tab. This drawer will now be your default fax drawer. When you exit back to the home screen you should then see the F icon on the drawer you selected.
        Cheers!
        • djbass
          • May 2008
          • 159
          If you mean output tray, normally it is set through 13 fax setting mode.
          13-930 set as follows:
          0 = inner tray
          1 = tray 1
          2 = tray 2
          Don't recall if its the same code on EBN devices.
          No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
          • Phil Walling
            • Dec 2015
            • 39
            Thanks for the help folks....
