HDD For 356 456
  • alireza7272
    • Aug 2017
    • 5
    HDD For 356 456
    I have 356 but this machin not have HDD.How I can Backup HDD wipe? Which Hdd I use for this machin?
    Please help me
    • 8155
    Re: HDD For 356 456
    The hard drive is located behind the system board attached to the top inside back of the copier via two metal brackets, specialized screws, rubber feet and cabling.
    If all of that hardware is gone from the used copier that you acquired your chances of getting this copier working are poor unless you can source another copier and take the parts.
    Plus you need the correct firmware and knowledge to to reload the operating system back into the copier.
    • clint@clintsimonsen.com
      • 120
      Re: HDD For 356 456
      It takes a standard pc HDD, just have a look in the back to check connectors whether it is a SATA or pata. Once the has in is (C+3) power on intz HDD (4+9) load firmware (0+8) 449, 947, 690 2
      Sent from my Nexus 5 using Tapatalk
      • decimal
        • Aug 2006
        • 75
        Re: HDD For 356 456
        Es356/456 used ANDI HDD model name is MK1661GSYG , it 's not standard PC HDD .
