can not start application in 455
  • ARMAN.MZ
    • Sep 2016
    • 100
    i have a 455
    after change hdd and update i see this error
    Can not start application
    whats the problem??
    Telegram ID : @armanmahzun
  • didi2005
    • May 2011
    • 401
    Re: can not start application in 455
    After replace HDD, did u performs 3C mode "All Partition Delete and Create Loader Partition" before proceed to firmware update?
    • ARMAN.MZ
      • Sep 2016
      • 100
      yes i did
      • didi2005
        • May 2011
        • 401
        When update firmware, is there huge different for firmware version?
        Try format HDD and update HDD firmware
        • ARMAN.MZ
          • Sep 2016
          • 100
          version 330
          i did it but not work
          • didi2005
            • May 2011
            • 401
            I've faced "cannot start application" error for e456 series, if HDD no issue, format HDD & update firmware can resolve the issue.
            • ARMAN.MZ
              • Sep 2016
              • 100
              problem solved
              The new hard disk problem.
              I bought another hard drive and the problem was resolved
              thank you all
