e195 bypass image skew
  • didi2005
    • May 2011
    • 401
    e195, when feed using bypass, image skew happen...Bypass rollers, separation pad, all in good condition...Seems that first 2/3 part skew where the last 1/3 part is ok...
    *Sample is copy counter list with horizontal straight line
  • gliderider
    • May 2015
    • 131
    Re: e195 bypass image skew
    Is this phenomenon happening when you try and print out an internal document like a function list. Is it happening from the paper drawer? It looks more like a ADF issue.
    • didi2005
      • May 2011
      • 401
      Copy via original glass, drawer feed ok, but bypass feed image skew, happen on A4 or A3...
      Noticed that when bypass feed, the beginning 2/3 of the paper go in, then stop for a while before the paper go in all and exit...As what I know is normal...
      Suspect the beginning 2/3 paper feed skew, but later straight back, thus paper printed out top & bottom edges are fine...
      • didi2005
        • May 2011
        • 401
        Removed 1 GUIDE-PUSH-TRU on the right, fold some paper and tape on the COVER-GUIDE-ASYS for some pressure on the right side, temporary problem solved, no more image skew when feeding from bypass...
