check 5008 code on toshiba e 306
  • nhatthuc0000
    • Dec 2007
    • 44
    I can't check and adjustment 08 5008 code when I login to service mode.
    can you help me.
    thanks so mush.
    Good luck to you!
  • Vincent128
    • Sep 2015
    • 342
    Re: check 5008 code on toshiba e 306
    That is because there is no 08-5008 for the ES-506 series.
    • nhatthuc0000
      • Dec 2007
      • 44
      I'm not thing so , on page 10- 36.
      Good luck to you!
      • Vincent128
        • Sep 2015
        • 342
        [ATTACH=CONFIG]39974[/ATTACH]
        not sure what manual you are in but.
        has no instances of 5008
        and the manual shows on the page you are referring to that:
        "39. Destination setting of toner cartridge"
        so...Find the correct manual and have a look at 08-5155
        We have all ours set to percentage of %3
        • nhatthuc0000
          • Dec 2007
          • 44
          I see, but i think it have some hidden code
          Thanks you more again.
          Good luck to you!
