how to printing on e350 -
  • aalex_bom
    • Jan 2008
    • 214
    i would like printing funtion on e 350, how i must do?.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    You will need to find a print enabler. This is a thumb drive like device that plugs into a spot on the right rear of the machine.
    • TheOwl
      • Nov 2008
      • 1732
      If you go to your local Tshiba Dealership and try and get on of the following.
      1. GM-1010 - This is the Print Enabler
      2. GM-1020 - This is the Print and Scan Enabler
      Other wise there is a 60 day trial that can be enabled to if you like the function. Once the 60 days are up, you cannot re-enable the trial.
      • aalex_bom
        • Jan 2008
        • 214
        USB
        I HAVE ONE VIOLET USB - ID GM2010
        I USED FOR 3 DAY, BUT SUDDENLY IT CAN NOT PRINTING.
        HELP ME, I CAN PRINTED NIC CONFIGURATION PAGE.PLEASE
        • TheOwl
          • Nov 2008
          • 1732
          My mistake, the GM-2010 is the Print and Scan enabler that you need.
          Is your machine set to a static IP Address or DHCP?
          • aalex_bom
            • Jan 2008
            • 214
            E 350 PRINTING
            Some body use e-filling function, but it is suppending, they shutdowned machine sometime. And now it not appear scan function.i can connect to ip by web
            • TheOwl
              • Nov 2008
              • 1732
              Do you have department codes setup on this machine? If you do, then you will need to set the pin code into the print driver.
              If you aren't using the deparment code, try a simple print using telnet with the following commands.
              telnet xxx.xxx.xxx.xxx 9100
              Replace x's with IP Address. Once you hit enter, you shoud get a blank screen with a flashing cursor. Type something and you should see the cursor move, but nothing on the screen. Hit enter a couple of times and then just close the command propmt window.
              This will send a print job directly to the printer. If it doesn't print out, go to the 'Job Status', 'Log', 'Print' and check to see if the last job has an error code against it. This code can be found in the user manual and will tell you what is wrong.
              If the job does print out, then you know it is just a simple matter of incorrect port settings within the print driver. Double check these and let me know how you went.
              • aalex_bom
                • Jan 2008
                • 214
                OK -
                E350 has printing, because one other change 08 - 201 to 2.
                Default is 0.
                Thanks verymuch
                but why my machine not printing continuese, when photo 2 side about 5 sheet it free run 10 second and printing 5 sheet then it free run 10 second and to be continued
