Disable WSD driver on Windows 10 for Toshiba?
  • kazihaha
    • 100
    [Misc] Disable WSD driver on Windows 10 for Toshiba?
    On some windows, I see that it auto install driver with port WSDxxxx for Toshiba e283.
    How can I disable this function???
    Disable on Toshiba or Disable on Windows?
    https://sieuthithietbivanphong.com
  • didi2005
    • May 2011
    • 401
    Re: Disable WSD driver on Windows 10 for Toshiba?
    U can try disable web services print via TopAccess so that it will not be detected by Windows and auto install print driver using WSD port...
    • kazihaha
      • 100
      Thanks I'll try it. Only in Top Access?
      • guitar9199
        • Sep 2016
        • 1100
        You can always configure a TCP/IP port after the driver gets installed.... Printer Properties> Ports> Add Port> Standard TCP/IP Port.
        • Vincent128
          • Sep 2015
          • 348
          Windows 10 loves to break things.
          Turn off Web print services on ALL Toshibas.
          If you have it on, Windows will go out and find this port, install the windows driver rather than the correct universal driver - most likely it will then be defaulted to printing through the bypass on thick paper...which makes all the jobs go invalid.
          ...oh, and it will do this without any prompts to the end users...
          • FrohnB
            • Jul 2017
            • 1919
            If they (Toshibas) have a Web interface you can log into, then I would do that and go into the configuration settings and disable all WSD settings on machine side. I also go into the settings (little cog icon when you click windows button in lower right) on Windows 10 and UNcheck "Let Windows manage my default Printer".
            Omertà
