Tray two wont lift.no error codes sensors chek out. Is it the lift motor pack ?one motor runs both.looks like tq limiter bad.first time on a toshiba b/w.
Common Problem, one motor runs both, probably little white idle gear inside pack, or one of the molded axles on the back half of the pack is broke off inside.
