e-studio 350
  • CuraGuy
    e-studio 350
    Hi,
    I am new to this forum room, I work in the uk for a company called Cura.
    I have a issue with a e-studio 350. i have ordered a new 40gb iee hard drive. but i need to install the firmware, i have looked on toshiba website and can not find it anywhere. Would any one be able to help me find the firmware or send it to me.
    Cheers
  • techman
    • Dec 2007
    • 49
    you need to go to fyi.com under tech to go you cant access it through toshiba website. If you are using fyi let me know and i will try to email it to
    • lucky777
      • Oct 2007
      • 54
      Toshiba usually has you connect through their FTP server and download firmware. You must request a login and password. At least for Canadians anyway.
      • CuraGuy
        fyi.com does not work. how and where would i sign up
        • Mr Spock
          Vulcan Inventor of Death
          • Aug 2006
          • 2064
          fyi.toshiba.com and you need to apply to be a dealer to gain access.
          • gitana1983
            • Mar 2009
            • 141
            toshiba e studio 350
            toshiba e studio copier iis making light copies I changed the developer unit and still having the same problem
            • lucky777
              • Oct 2007
              • 54
              Cleaner the optics and the slit glass for the laser. In digital copiers, copies get light when optics are dirty. In analog they get darker.
              How old is the drum. How many copies on it??
              • BigDog
                The es350 have a habit of running light. If you have changed the drum and developer. Did the 08(200) the next thing I would try is to set the Auto density 05(514), 05(512), 05(515). these setting go from 0 to 255. The higher the number the darker the copy.
                • lucky777
                  • Oct 2007
                  • 54
                  Not sure what you mean we have a few hundred of them out in the field and they keep color fine. Usually solids are great after a quick cleaning.
                  • jayc67
                    Independent technician
                    • Sep 2009
                    • 100
                    Hi,
                    i'm from France. I search parts for toshiba e-studio 351C. If anybody know a supplier in Europe, can you tell me?
                    • jcontractor
                      • Aug 2010
                      • 247
                      Originally posted by jayc67
                      Hi,
                      presicionroller.com
