Tosh ES 352 electronic meter is frozen. No longer increments.
  • Jammed
    • Jun 2015
    • 33
    [Misc] Tosh ES 352 electronic meter is frozen. No longer increments.
    Went out to check the meter... Same count as last year. Meter is stuck and will not increment. I think the last thing done was to replace the EPROM for a fuser code that wouldn't go away. C440 ? I think. Regardless, any ideas how to get the meter to increment again? TIA
    It looks like 0/8 mode 257 or 302 or 769 or 1548 may help. Not sure.
    -Steve
  • Thayer
    • Dec 2017
    • 107
    Re: Tosh ES 352 electronic meter is frozen. No longer increments.
    Is it in line mode or service mode??
    I believe it's
    08/203
    1 is service mode
    0 is counting clicks
    • tsbservice
      Field tech
      • 8020
      Why one didn't use PM instead of reply
      • Jammed
        • Jun 2015
        • 33
        What do you mean? Why not just reply?
        • tsbservice
          Field tech
          • 8020
          Check your PM.
