EStudio 4511 Envelope feeder?
  • jasonblewis
    • Jul 2008
    • 27
    Hi Guys,
    Is it possible to print onto DL size envelopes on the 4511? if so, how do you do it?
    Thanks,
    Jason
  • lucky777
    • Oct 2007
    • 54
    Stupid question , but what is a DL size envelope? Do you meen LD?
    I know usually Toshiba machines above 28 copies per min don't do regular size envelopes properly. You know if you put it in the bypass and see " media Type" options at bottom of screen. Choose it and if you see envelope option beside the "thick" & "transparency" options then you can to envelopes, if not your usually beat.
