Toshiba 5560
  • loidy
    • May 2025
    Toshiba 5560
    Hi, My Church has recently aquirred a 5560 with 1.3 mill clicks on it. I went to clean it and after I cleaned a few simple things it now has a error code on the display of 0 and call for service is displayed. What did I do? How can this error be cleared? I know on Canons we can go inot to service mode and clear soft error codes.
    It warmed up and made copies before it got moved 100 ft, and also before I "cleaned" it, it warmed up and made blank copies!!! Now I have 2 problems to fix!!! Any help would be awesome, as I am doing this for the big guy!!
    Greg
  • tsbservice
    Field tech
    • 7911
    Hold down Clear+8 simultaneously while machine gives call for service and post error code, as for blank copy crash the machine to stop copy under drum and check for image if drum has image inspect transfer charger if not main charger, also post what and where did you do cleaning before error pops.
    • loidy
      Thanks for the reply......As for the cleaning all i did was clean the glass and mirrors while it was warming up, after the blanks came out I removed the prirmary and transfer corona's and cleaned and checked them for broken wires. I will get back to you on the service code as will be checking it out again on Sunday
