Toshiba es120 Oldie
  • blackdog
    • Jun 2012
    • 211
    Toshiba es120 Oldie
    Hey Gentleman & Ladies, sold this es120 back around 2000. 1st service call the other day. I know wow.
    25k Maintenance Icon on display, new drum and developer and reset maintenance icon.
    Now my issue is I can't reset wrench for the life of me...
    Cosmos won't reload on desktop, and checked out Sharp Service Manual to wits end.
    What's up with this oldie but goodie....I use the term loosely..
    • 8105
    Re: Toshiba es120 Oldie
    Toshiba Japan ended support for this model in 2017. Toner, parts and tech support are no longer available from Toshiba.
    You need to say too bad, so sad and move on.
    A shiny, new eStudio 478s would be the perfect solution.
    • guitar9199
      • Sep 2016
      • 1099
      Did you clear the SIM codes? (24-06) (20-1)
      • rapidocument
        Multibrands Tech
        • Jul 2012
        • 381
        Toshiba E-Studio 120 / 150
        Diagnostic access:
        Press Clear key, exposure mode key, clear key, exposure mode key.
        Press number of code using 10s and 1s key. Press "Start."
        Enter the number of the sub code. Press "Start" key
        To quit: turn off the machine.
        20/01: Clear PM count.
        24: Sub code 01: Clear jam counter.
        Sub code 04: Clear SPF counter.
        Sub code 06: Clear developer counter.
        Sub code 07: Reset drum count, turn off drum light.
        Sub code 08: Clear copy counter.
        Sub code 09: Clear printer counter.
        Sub code 13: Reset scan counter.
        Sub code 14: Clear SPF jam counter.
        Sub code 15: Clear scan counter.
        My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
        • lazymangr
          • Feb 2017
          • 115
          toshiba 478s isnt a rebranded lexmark?
          • tsbservice
            Field tech
            • 7926
            Cleared a lot of these POC Sharps. Do like others said and tell them to upgrade as soon as possible.
