Toshiba eStudio45 admin troubles
  • rdj357
    We're working on a Toshiba eStudio45 with a GL-1010 controller running software version 1.0.4.3 - We can't get past the admin password/pin in order to set it up properly for the network. Is there a workaround for this? Thanks, Robert
  • Hallmark
    • May 2006
    • 23
    I am not trained on this controller, but I do know that the default admin password is 12345. This part I am not sure of, but when you start the copier while holding down the START and 9 you will go into a printing mode. Key in 102 and the copier will print out all the 08 settings. At the very end of the print out will be printed the master code. I think that will be the admin code you are looking for, but I am not sure if it is the same as the controller code. Also, if you reinstall the controller software the administrative code will be reset to 12345. Hope this helps.
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      the default on the gl-1010 is 1234 or 1087 or 1078. Usually 1234 though.
      • rdj357
        Resolved
        Thanks for the replies, unfortunately nothing got us there. We reinstalled the controller software and it was reset back to 12345.
        Thanks for taking the time tho!
        - Robert
        • decimal
          • Aug 2006
          • 75
          hi Robert!
          Do you have Recovery CD-rom for GA1010 ? We are needing it for our es-45 .
