Toshiba E studio 257 firmware
  • innokileo
    • Mar 2017
    • 7
    Hellow Tech, I need firmware for this machine, the HDD crushed, I got new one but I don't have firmware, anybody with it plze I'm in need
    Re: Toshiba E studio 257 firmware
    if you are a certified tech you will have access to that via the support portal.
    do you have a service manual? once you reload software you will have to start setup procedure over again.
    IF you aren't a tech.. I suggest you hire one.
    • riyadh hossainbd
      • Dec 2015
      • 239
      Inbox me
      • A1yn88
        • Oct 2018
        • 1
        Hello, did you solve the problem?
        I have exactly the same problem and I need firmware.
        • MacTavishLK
          • Nov 2020
          • 67
          check pm
          • MacTavishLK
            • Nov 2020
            • 67
            check pm
