I just did some maintenance on two of my 3511s . I did a 05-396 on one at firmware 110 and it executed. I did 05-396 on my other unit with firmware 4006 and the "wait" message appeared and disappeared for a split second and nothing happens. Was this changed in the newer firmware, and what procedure should be done when replacing drum, transfer belt and EPU Kit?
Toshiba 3511 Image Quality
When you replace any PM parts in this machine you need to go into PM support mode (start+6 select 2) and clear the maintenance counters for the items you replaced. If you replace the developer material you can initialize the developers using PM support mode (start+6 select 1). After doing 05 396 all that is left is to perform the gamma calibrations.
I am not sure why you got the 'wait' message on the machine with 4006. The firmware version has nothing to do with the IQ initialization. -
Try print some calibrating under 05 mode - 4+FAX, if you can't then reload firmware."A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it"
"What do you despise? By this you are truly known"
Guess who
The cal charts print without problem, they are bright and rich just as the prints are.Come to think of it, I don't ever remember this machine doing an auto calibration since I had it. My other ones do it sometime when first turned on and they always do it after a large print job.
What would be the number to switch the IQ back on since I don't see it in the manual?Comment
3511 IQC
08-549 SET TO 1
08-551 SET TO 1
08-552 SET TO 1
08-553 SET TO 1
08-554 SET TO 1
08-555 SET TO 1
08-556 SET TO 1
08-557 SET TO 1
08-559 SET TO 1
Check and set all these codes this will switch on the "IQC" take a note of previous settings as IQC may have been switched off for some reason and you may start getting IQC error codes appearing.Comment
