Error bios mode 2006
  • armin2570
    • Jun 2015
    • 44
    [Error Code] Error bios mode 2006
    HI
    At estudio 2006 show this error
    What should I do?
    Thanks lot
    Re: Error bios mode 2006
    Originally posted by armin2570
    HI At estudio 2006 show this error What should I do? Thanks lot
    [ATTACH=CONFIG]41894[/ATTACH]
    [ATTACH=CONFIG]41895[/ATTACH]
    buy a service manual
    or hire a tech
    • armin2570
      • Jun 2015
      • 44
      or hire a tech
      I have service manual but if you don't know solution no need answer and write any thing here
      • armin2570
        • Jun 2015
        • 44
        I probem resolved by updating with the usb device or should I do firmware updating with BIOS MODE by ((updateFW.exe)) ptogram
        I haven't program ((updateFW.exe)) and firmware for this progarm
        • riyadh hossainbd
          • Dec 2015
          • 239
          HI
          What should I do?
          Thanks lot
          U have to do firmware update with PC update tools
          • tsbservice
            Field tech
            • 8008
            HI
            What should I do?
            Thanks lot
            1. From your post nobody can understand that you have SM.
            2. To have SM doesn't equals to read it and know what you're doing.
            3. If you simple need Firmware, then why not just ask for it?
            • didi2005
              • May 2011
              • 401
              When you want to update the firmware to the latest one or the equipment becomes inoperable due to some defect in the firmware, updating can be performed as follows.
              Updating with the USB device
              Firmware Updating with PC Update Tool
              Firmware Updating with BIOS mode
                I then prove you have manual and have read it
                • armin2570
                  • Jun 2015
                  • 44
                  when i want firmware update by usb device show this massage and no any action
                  do any one program this program ((updatefw.exe)) for updating with bios mode
                  • riyadh hossainbd
                    • Dec 2015
                    • 239
                    [ATTACH=CONFIG]41953[/ATTACH] [ATTACH=CONFIG]41954[/ATTACH]
                    [ATTACH=CONFIG]41955[/ATTACH]
                    There are two file in es2006 firmware . U have to rename it ".bin" . Then update
                    • armin2570
                      • Jun 2015
                      • 44
                      Have any body program ((updateFW.exe. exe)) for update by pc
                      • armin2570
                        • Jun 2015
                        • 44
                        no accept firmware update by usb device i think should update with pc update but i have not program ((updatefw.exe))
