e45 alway paper jam - "misfeed in copier"
  • aalex_bom
    • Jan 2008
    • 214
    when copier paper jam, we moved paper but cover closed, duplex Closed, copier can not "ready"
  • mckinley
    Chief Twiddler
    • Dec 2006
    • 150
    what error code are you getting?
    i would look at the fuser exit sensor, they commonly fail due to constant heat.
    also i would check all sensors to see if one is being held back by a small piece of paper.
    Happiness Is The Road.
    • aalex_bom
      • Jan 2008
      • 214
      TURN OFF to ready
      IF I turn off and turn on again then it can run, but when COPIER jam, i take over any paper out then i must turn off copier and restart.
      • Sbarro
        • 176
        Yeah. It's front cover sensor ) I had this twice (E45 and E232). Good luck.
        "A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it"
        What do you despise? By this you are truly known"
        Guess who
        • aalex_bom
          • Jan 2008
          • 214
          why
          i changed sensor, not ready.
          • mckinley
            Chief Twiddler
            • Dec 2006
            • 150
            you changed which sensor? door? fuser? both?
            does the machine have an LCF? if it does, you have a few pointers...
            broken LCF feed housing ( rocking backwards & forwards at rear side )
            button switch at rearside of LCF not making properly when side door closed.
            microswitch not operating when you close LCF door ( located behind lower side cover nearest floor ) you should hear that click when you open & close the door.
            & finally, the wiring harness for the LCF ( this applies to pedestals also ), if it's not properelly plugged in to the machine, it confuses the logic & makes the machine think it has the other option ( ie: if it has an LCF it thinks it has a PEDESTAL )
            as for the error code? you didn't give that. if you press clear & 8 together you should get the error code.
            good luck.
            • aalex_bom
              • Jan 2008
              • 214
              have not
              not LCF, not code when i press clear and 8 hold. because it have not "call sevce.." message.
              i changed sensor, checked door, fuser.
              when i close front cover or duplex unit I hear that "click" and ADRF run for 2 second.
              • Sbarro
                • 176
                It must be one of the sensors. Try to switch them for example duplex sensor with lower feed sensor.
                Guess who
                • aalex_bom
                  • Jan 2008
                  • 214
                  WHY
                  are you understand? I turn on copier, copier "ready " and I copy more 20 sheet, copier ""tip" sound and "misfeed in copier" message. I left paper out but copier not ready after I close all cover and duplex unit.
                  • Sbarro
                    • 176
                    I UNDERSTAND I HAD THIS TWICE !
                    How can you explain fact that behavior is identical and front cover sensor WAS damaged ?? After replace it works good. I still thinking that is one of the sensors in your case.
                    Have you reload firmware yet ?
                    Guess who
                    • mckinley
                      Chief Twiddler
                      • Dec 2006
                      • 150
                      you get an error code for jams aswell as call for service. if you look at the screen when the machine jams, you may already see an error code, if not press the clear/stop button & 8 at the same time.
                      the error code would make a big difference in pin pointing a possible solution. when the machine jams are you making sure to open every cover? even the ones not in the jam area? because some jams will never clear unless you open every possible cover, then when they are all open, close them one at a time.
                      when the machine does jam, where does the paper stop?
                      • aalex_bom
                        • Jan 2008
                        • 214
                        firmware update
                        thanks
                        I THINK THAT FIRMWARE NOT PROBLEMS BUT I RELOAD FW YET and front cover have not sensor, have only LS (switchs)
                        ERROR HISTORY OF DATA LIST "08"
                        E13
                        E72
                        E01
                        E74
                        C14
                        C13
                        E22
                        E73
                        when the machine jams are I making sure to open all cover, after close them one at a time.
                        i must tunr off.
                        help me
                        • tsbservice
                          Field tech
                          • 8082
                          This will happens when you replaced HDD and forgot to plug in front cover push switch.
                          • Sbarro
                            • 176
                            My english is not perfect Switch or sensor ... You know what i mean.
                            Maybe the switch is ok but your front cover is damaged in some way ?
                            Guess who
                            • aalex_bom
                              • Jan 2008
                              • 214
                              by hand
                              thank tsbservice
                              i replaced hDD, i not forgot to plug in front cover push switch because i unpluged power cable. but how to i must solute?
                              thank Sbarro
                              I tested by hand and screws.
                              plastic cover ok.
