instal new m cartridge in toshiba 3540c
  • mohsep
    • Mar 2019
    • 8
    hi evrey body any one can help me ,new machine 3540c work normal , but after some copies there is massge inttal new maginta cartridge ,i replaced m cartride , adjust auto toner for all colors , is thear any action ?
    • 22808
    Re: instal new m cartridge in toshiba 3540c
    what does the manual tell you to do?
    are you an end user?
    • mohsep
      • Mar 2019
      • 8
      No i am technical ?
      But this error is new for me
      • toshibaestudio
        • Jun 2016
        • 116
        Make sure genuine toner is used...
        I have cases where genuine toner more than 70% also showing "Install New Cartridge" error.
        When dealing with toner issue, I always perform below steps:
        1. Change another new toner
        2. Clean the CTIF toner sensor - "Toner not recognize" error
        3. Check developer tank, make sure toner is not overflow - Too much toner inside developer tank
        4. Replace auto toner sensor underneath the developer tank - So far never replace before
        5. Perform auto toner adjustment for the problem color only before replacing new developer material
