4054 wont load toner just makes noise?
  • Ricoh5150
    • Mar 2019
    • 6
    The bottle seems to be turning
    Re: 4054 wont load toner just makes noise?
    well now.. do you think you can shorten the explanation a BIT?
    PAGE COUNTS..
    ERROR CODES..
    PM's done on time?
    OEM or Compatible Toner?
    Are you a tech?
    PhilB " The Dentist "
    • guitar9199
      • Sep 2016
      • 1100
      I saw this once... Customer loaded the WRONG toner in the machine.
      • Ricoh5150
        • Mar 2019
        • 6
        PAGE COUNTS..
        ERROR CODES..
        PM's done on time?
        Are you a tech?
        Yes.. I opened service mode(output) turned on toner bottle motor the bottle would not turn unless pushed in slightly.
        After doing that it added toner. Then I turned the bottle counter clockwise manually and now it works.
        PM are complete
        OEM Toner
        No error
        500 K
        • Ricoh5150
          • Mar 2019
          • 6
          Still wont add toner
            Try affixing a block of foam on the door to push bottle in more.. had a b&w ricoh years ago we had to rig like that to get it to work...
            • FrohnB
              • Jul 2017
              • 1919
              Wrong toner loaded? Competitive Toner (Can look the same, but bottles can have slight differences).
              What's the count on developer UNIT (not just developer, but the unit)?. Have seen one, where the toner supply assembly had to be replaced because of seized gears on Dev. Unit.
              Toner Supply Ass'y. - D2023051 Big PITA to replace.
              Omertà
              • Ricoh5150
                • Mar 2019
                • 6
                I just removed the controller and took apart TSU and broke it.
