OSX 10.14 Mojave Dept Codes
    • 8193
    Has anyone found a Toshiba print driver yet that works well with Dept Codes on a Mac OSX 10.14?
  • toshibaestudio
    • Jun 2016
    • 116
    Re: OSX 10.14 Mojave Dept Codes
    For OSX 10.14 built in apps, the text box to enter dept code is missing, u can create a preset that store the dept code using other app such as chrome. Make sure the dept code is enabled under printer features.
    • Aethanite
      Service Technician
      • Oct 2012
      • 42
      I generally use CUPS to enter the department information on our mac clients. Two reasons we do this is due to a few 'discussions' with people in regards to colour printing "Even though the page is black and white" scenario. So we go in and make sure its set to mono by system default.
      The second is the department code reason. Some people get confused over the presets and how they work ... so again while in CUPS, we go to the department code section and enter the numbers so it doesn't matter what preset or print job they use, it will have that department information stored at a system level.
      To enable CUPS, open the Terminal and type (exactly)
      cupsctl WebInterface=yes
      Then open Safari (or other browser) and navigate to
      localhost:631
      This will present you with the CUPS home page where you can manage the printers at the system level.
      Hope this helps!
