E-Studio 233
  • kashif
    • Apr 2013
    • 45
    E-Studio 233
    i have toshiba 230, i have paper in tray 1 & 2 but machine also saying add paper, tray is not lifting, i clean every thing even i checked lift up motor, everything seems good, someone can help
    Re: E-Studio 233
    ok so the machine doesn't see paper in the trays...
    what tells the unit that there is paper in the tray?
    (hint** paper sensors in tray)
    find the sensors in parts IPB... check for proper movement-clean or replace
    • kashif
      • Apr 2013
      • 45
      Re: E-Studio 233
      Both tray's are not lifting, i cleaned all sensor even i also checked lift up motor, everything seems good
        Re: E-Studio 233
        both tray's are not lifting, i cleaned all sensor even i also checked lift up motor, everything seems good
        clearly "everything is not good"
        go back to diagnostics
        • djs9164
          • Mar 2018
          • 79
          Re: E-Studio 233
          Broken gears on back of tray, is the motor turning on. Help us out here.
          Sent from my XT1635-01 using Tapatalk
          • kashif
            • Apr 2013
            • 45
            Re: E-Studio 233
            gears are ok, motor is not turning on, but manually i checked motor is ok, i am looking code for lift-up-motor in test mode
            • gliderider
              • May 2015
              • 131
              Re: E-Studio 233
              Those copiers were known for breaking gears in the tray lift gearbox. Remove the gearbox and try and turn either coupler. If you can't than there are gears or the standoffs that hold the gears could be broken within the gearbox. The gearbox is cream colored and has one connector. It sits in the bottom left corner in the back of the copier.
              • kashif
                • Apr 2013
                • 45
                Re: E-Studio 233
                boss i checked that box (Lift-up-Motor) all gear is ok,no any broken
                • toshibaestudio
                  • Jun 2016
                  • 116
                  Re: E-Studio 233
                  How to justify the tray up motor is working without any output test?
                  If insert drawer and tray did not lift up and cannot hear any motor noise, most probably the motor problem...
                  Is very common for this model where the tray up motor black wire easily broken...
                  If can hear cracking noise when lifting up, probably some gear or the housing is broken...
