E Studio 5055C / Cant remove black drum or TB unit
  • wild140
    • Feb 2017
    • 70
    Per the SM seems to be relatively easy , I can pull out all other colors and black DV but black drum seems locked.
    Also can not remove TB Unit I removed the Cleaner , Turned the lever in the upper front clockwise , loosened the two screws and dropped down the grey holders ( Levers that the screws are in) . Seems like the front is loose but not the back . Do not want to force either , Is there a trick ? Could the belt still be engaged and if so how do you release it ?
  • Edward
    • May 2019
    • 32
    Re: E Studio 5055C / Cant remove black drum or TB unit
    The tranfer belt is holding the drum tighten the tb back and try again
    • rspicer
      • Oct 2015
      • 97
      If the transfer belt release has been turned too far, it twists or breaks the shaft, which does not allow the rear to release. It is major disassembly to replace that shaft, and you just about have to break the drum unit and transfer belt to get them out.
